It is currently Mon Jan 20, 2020 5:44 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: 66K Disassembler
PostPosted: Tue Jan 14, 2003 7:36 pm
Here is one of the most wanted tools for the OBD1 ECU Hackers.
A Disassembler for 66301, 66201 and 66207 Processors.
Put both files in one directory and launch the .EXE.
Enjoy
Doc
 Post subject: Re: 66K Disassembler
PostPosted: Tue Jan 14, 2003 10:11 pm
just also put the asm and we will be so happy that no one will fit on their asses :)
thanks a lot!
PostPosted: Tue Jan 14, 2003 10:31 pm
sorry sir it doesn't work ...
it starts with the reset vector and loop a few times, puts some lines with *, and then 'finished blah blah blah'
PostPosted: Tue Jan 14, 2003 11:40 pm
works fine for me using some P28 roms.
PostPosted: Wed Jan 15, 2003 7:15 am
shit i found my bug.... somehow the 66207.op file was renamed to 66207.op.txt!!!!!
now it works like a charm!
PostPosted: Wed Jan 15, 2003 8:56 am
Outstanding Job! This is one I have definately been waiting for.
PostPosted: Wed Jan 15, 2003 11:58 am
I wish I could code in ASM, but damn his is good software
PostPosted: Thu Jan 16, 2003 9:09 am
Woooooohooooooooooo!!!!!!!!!!!!!!
PostPosted: Thu Jan 16, 2003 2:52 pm
Thats just stunning - what a star!
PostPosted: Thu Jan 16, 2003 4:33 pm
Well, doc, you could have add a "Save to file" menu at least... :))
PostPosted: Thu Jan 16, 2003 8:53 pm
New Version!
New features:
"smartwriter" - add the jump and call references
"save .TXT" - save the disassembly to a .TXT file.
You need the new .OP file, too!
PostPosted: Fri Jan 17, 2003 3:52 pm
As good as this is, & I hate to sound like I am complaining, but I have a problem. The program freezes when DASMing a whole ROM when it gets to about address 0BC0.
I'm running it on windows 98.
I'll run it in smaller blocks & stitch them together, but then the smartwriter doesn't work. :-(
Do you have the opcodes in pdf format by the way? I can only find a summary & the scanned tiff document.
PostPosted: Fri Jan 17, 2003 5:51 pm
there are no PDFs of the opcodes. The DASM was written with the help of the TIFFs.
PostPosted: Fri Jan 17, 2003 8:41 pm
In that case, I have access to Adobe software & will be attempting to pdf the tiffs sometime next week. I tried a page yesterday & it was only partially successful (due to the photocopied quality) but the headings seemed to convert ok. This should make it at least partially searchable.
PostPosted: Fri Jan 24, 2003 3:01 pm
No, Doc has the ACTUAL manual :)
